Speedometer Rebuild
I am cannabilising 2 speedometers to make a good one for an S4 Elan. Can anyone advise on whether it is best to use a bit of grease or oil on the nylon worm gear drive? Also, is there a particular method in removing the speedo head assembly from the case? I have gently tapped out the pin holding the zero odometer extension adjuster and removed this but it still seems difficult to extract the head??
- William2
Do you have these documents / links? Pretty comprehensive stuff that may help. Sorry, I ended up sending both my tach and speedo off for repair, so not sure on your specific questions.
http://home.comcast.net/~rhodes/PDF/speedo.pdf
http://www.74tr6.com/gauges.htm
http://www.youtube.com/watch?v=EoTkZGleYbM
http://www.mgaguru.com/mgtech/dash/dash_1.htm
HTH
Stu
HTH
Stu
Stu
1969 Plus 2 Federal LHD
stugilmour wrote:Do you have these documents / links? Pretty comprehensive stuff that may help. Sorry, I ended up sending both my tach and speedo off for repair, so not sure on your specific questions.
HTH
Stu
Thanks for the links (the first one no longer works though). After removing the innards of my Elan Speedo to refurb the case, several parts were loose The last of your links provided the answer to my thankfully short lived dilemma!
Does anyone have any original drawings of the gauges they could spare?
Karl
1970 S4 FHC SE
1970 S4 FHC SE
fasterbyelan - Third Gear
William
To extract the speedo innards, I had to remove the pointer and dial first.
Two levers removed the pointer easily, being careful to protect the dial surface. An extractor as in the photo would be good but I had no trouble.
The dial is held in place just with the two screws near the centre.
The works are held in the case by the two screws on the back.
I do not know about lubrication.
Best of luck
Eric in Burnley
1967 S3SE DHC
Best of luck
Eric in Burnley
1967 S3SE DHC
- ericbushby
Thank you for your reply. Need to get stuck in now!
If anyone needs to replace the bezels/glass/seals on their gauges I have received good service from here - http://www.autoelectricalspares.co.uk/bezels-glass--seals-for-smiths--lucas--jaeger-gauges-68-c.asp.
Karl
1970 S4 FHC SE
1970 S4 FHC SE
William,
I never figured out how to get the mechanism out of the case. The odo zero pin wouldn't clear the bottom of the case before the top of the mechanism hit the top of case. In the end I decided I was likely to break it, so put it back together.
If you find the trick to it please describe it here!
Nick
Nick
elanner - Fourth Gear
elanner wrote:William,
Nick
Hello
no comment:
ElanDNA - Second Gear
I just found the trick on u tube. There is a pin in the rubber on the shaft of the trip reset, near the case end. I got it out by starting it with a small screwdriver and then a small pointed tool until I could grip it with pliers. It's very small don't lose it! With the knob end off, the remaining part, about a half inch, clears the case easily.
I'm now looking for how to clean and lube the mechanism without taking it apart. Like you I don't feel lucky!
We are supposed to be having fun, are we not?
- USA64
Whatever you do don't use normal automotive Lithium based grease on Nylon gears. Over time it will cause the plastic to deteriorate. Use something that's compatible with plastics - eg. Silicon based or special grease for plastic.
https://www.electrolube.com.au/products ... nd_grease/
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
2cams70 wrote:Whatever you do don't use normal automotive Lithium based grease on Nylon gears. Over time it will cause the plastic to deteriorate. Use something that's compatible with plastics - eg. Silicon based or special grease for plastic.
How different is Vaseline?
Love your Mother
Earth
Love your Mother
Earth
Users browsing this forum: GaryE and 19 guests
