S4 Wiring Diagram
I converted Gareth Flanagan's excellent wiring diagram from the tech section from DXF to a PDF file so many more of you can read it:
enjoy!
enjoy!
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Thank you, this is really helpful and good timing for me,
- Stratosboy
I also did this, printed at A3 and laminated at work, very useful thing to keep in the car.
I've attached my effort as I had to resize the legend text to get it to line up properly, and I changed the base colour from turquoise to grey so it was clearer.
- Attachments
- Lotus Elan S4 Wiring Diagram.PDF
- (79.72 KiB) Downloaded 1651 times
Steve G - Third Gear
Thanks for this diagram, really easy to follow.
Because of the quality attained with this I was thinking, wouldn't it be great to have the Author (or anyone else who's capable), provide us with a similar one including some of the 'upgrades' ..........
I was thinking, with the inclusion of perhaps:-
Alternator
Geared Starter
Electronic ignition
Correct headlamp flasher wiring layout
Additional fuses
Electric fuel pump
Water temp /otter fan switch
Etc.......????
(Some people are never satisfied are they!)
Phil.
Alternator
Geared Starter
Electronic ignition
Additional fuses
Electric fuel pump
Etc.......????
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
l10tus wrote:Etc.......????
How about the 'Fasten Seat Belt' light on the dash? Included is the wiring going to each seat belt stalk. I don't know how common it is but it's on mine, 0243K, January '72 .
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
l10tus wrote:Thanks for this diagram, really easy to follow.
Alternator
Geared Starter
Electronic ignition
Additional fuses
Electric fuel pump
Etc.......????
Phil.
If you send me a scanned in sketch of the modified diagram I would be happy to CAD it up.
Dear All:
I am about to send my '69 S-4 to a local auto-electric shop to tidy up my wiring and help me get my ignition switch working properly. They have requested a wiring diagram, so I plan to color print the the excellent diagram Gareth, Phil, and Steve did in 2013 (see above) on 11x17 paper.
I'm no electrician, but doesn't this diagram indicate a positive, rather than a negative ground? This would certainly not be correct for an S-4.
Many thanks!
-John
Many thanks!
-John
John Beach
'69 Elan S4 DHC - A Work in Progress
- jbeach
jbeach wrote:I'm no electrician, but doesn't this diagram indicate a positive, rather than a negative ground? This would certainly not be correct for an S-4.
-John
Indeed it does .... Just swap the +ve & -ve symbols...
Phil Harrison
I printed my color schematic on a 2' x 3' (or so) paper, then had it laminated. All can be done in a FedEx
store. Well worth it! I can guarantee this won't be the last time you refer to it. Dirty fingerprints can be wiped off, and the paper is preserved.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
Excellent, Greg!
So, I email the schematic .pdf to the local Fedex store and have them print it? Perfect. 11x17 (my max, in-house) is clearly not large enough, unless you have a really good magnifying glass.
Thanks!
-John
Thanks!
-John
John Beach
- jbeach
I brought it to them on a thumb drive. They know how to keep things in proportion when blowing it up
so as to not go too far.
edit: Ok, so I was a little optimistic. I measured the schematic and it is 19" x 24" with a bit of laminate
overlap. Perfect size to follow the wires.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
