Dynamator Conversion
• Page 3 of 3 • 1, 2, 3
I think I will do it this way first - just keep the existing control box and wire it up to see if it all works.
Then rewire and remove the control box at a later date.
billwill wrote:You can remove the dynamo control box, but alternatively you can just move one wire from one terminal to another, I forget which, but we detailed it earlier this year. Then it still look original.
Part of the current will then flow through a small portion of the control box, but it will have no significant effect on the function of the alternator.
Strictly speaking you should fit a thicker wire (brown green ?) from your new alternator to the control box and then from there a thicker brown wire to the terminal on the starter solenoid. . That wire is the main feed from all the electrics to and from the battery.
1967 Plus 2 #0168
- Johnfm
windscreen washer motor and heater connections will also need swapping, I having suffered a winter years ago with the heater fan motor working but sucking instead of blowing through the matrix ! Not something you would consider, or I didnt drrrr
- weddingcarclive
Users browsing this forum: No registered users and 44 guests
