Reverse lamp switch on early +2
I?m desperately searching the reverse switch on my 68 +2, I have found in the archive that is on the top of the gearbox near the bell housing.
According to the picture it?s the part number 73, is it under the cover(33) ?
I can?t locate it on the car. Is it possible it has been replace by an ordinary screw ? Can I change it without taking out both engine / gearbox ?
What is the right way of the two wires ? on the chassis? Or in the interior ?
Franck
Franck
50/0302 +2, Frogeye
spridget - Third Gear
Hi Franck,
The switch is located in front of the top cover........
On the two seater Elan the switch is accessible (just) from the engine bay but I don't know if the same would be true for the + 2.......
S4 DHC
S4 DHC
- oldelanman
Hi Franck,
According to Brian Buckland's book the reverse lamp switch did not appear on the 4 speed box until the introduction of the Elan S4 model in 1968. Maybe your '68 + 2 was built with the earlier 4 speed box which did not have the switch?
If your rear lamps have provision for reversing lights you could consider fitting a switch on the dash to operate them manually.
S4 DHC
S4 DHC
- oldelanman
