Ignition Warning Light glowing while running
Can someone help please?
Since recently the ignition warning light of my S3 no longer stop glowing once the engine is running. I drove the car 60-70 miles since this occurred and the battery is still working normally. To me it looks as if the generator is still working all right.
What could cause the warning light not stopping glowing??
Thanks.
Olivier.
Thanks.
Olivier.
- Vanden Perre
Does your car still have a DC Dynamo or has it been converted to an AC alternator?
In my experience, if you have an alternator and you get that constant glowing, it usually means that the diode pack in the alternator has destroyed itself.
The best cure is to fit a replacement alternator, but you can change the diode pack yourself if you can use a soldering iron.
If you still have a dynamo those symptoms can (I think) be caused by a faulty regulator box. Clean the relay-like contacts, that might fix it.
Bill,
You are right. I forgot to mention something important. I still have the generator.
Olivier.
Olivier.
- Vanden Perre
Dear Olivier,
If you're feeling really rich you could try one of these - http://www.autoelectricsupplies.co.uk/p ... tegory/141
Best,
Best,
Mazzini - Coveted Fifth Gear
It appears the Elan is similar to the lump I am working on at the present time. In that, the ignition warning light requires battery voltage from two directions to extinguish the light. The light first gets its voltage from the ignition key. Then gets voltage from the regulator/control box, back fed, when the engine is started and the generator starts charging. If the back fed voltage is not present, the light will not extinguish. Believe me, I had the same sort of problem, and chased what I thought were generator/control box problems, until I found an open circuit from the control box. You might check the wiring between the control box and the warning light.
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
To m750rider, you were right. The dynamo was broken. I brought it to a workshop and they noticed that the bronze bushing and the end opposite to the pulley had so much play that the rotor touched the stator and was damaged and in short circuit. I decided to buy a new one and just finished to install it. But.....see other post.
Olivier.
Olivier.
- Vanden Perre
