Crossflow (capri/cortina) alternator mount
PostPost by: bertavfc » Thu Apr 04, 2013 12:31 pm
Hi, I'm rumaging together bits for a looming alternator conversion on my 69 +2, I've just souced a crossflow bottom alternator mount that was described as a Capri/cortina item, I've been searching the threads on here and have struggled to get a definative answer to the best item for this conversion, I've heard the pinto item a a good way to go but the ones I seen came with 3 mounting lugs to the block as appose to two?, I apolagise if I'm going over old ground in advance, I've believe it's still acceptable to re-use the existing dynamo tensioner bracket (I'm fitting a 18 ACR unit), best regards, Rob.
Item can bee seen here http://www.ebay.co.uk/itm/151020665018?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
bertavfc
First Gear
First Gear
PostPost by: 512BB » Thu Apr 04, 2013 1:17 pm
Er Rob,
I trust your monica is not making reference to a certain northern football club, as that would be totally inappropriate.
Leslie THFC
Why don't you watch a good game tonight, they will be completely BALED over.
PostPost by: fatboyoz » Fri Apr 05, 2013 2:13 am
Rob,
If you go to the SJ Spotscars (located in the UK) site and select: your car, electrical, alternator they have the three items you need to mount an alternator. Lower mount, adjusting strap (top mount) and bracing plate. The double legged adjusting strap and bracing plate are used to spread the load of the top mount over three bolts, instead of one, to protect the alloy front cover from cracking.
Colin.
bertavfc wrote:Hi, I'm rumaging together bits for a looming alternator conversion on my 69 +2, I've just souced a crossflow bottom alternator mount that was described as a Capri/cortina item, I've been searching the threads on here and have struggled to get a definative answer to the best item for this conversion, I've heard the pinto item a a good way to go but the ones I seen came with 3 mounting lugs to the block as appose to two?, I apolagise if I'm going over old ground in advance, I've believe it's still acceptable to re-use the existing dynamo tensioner bracket (I'm fitting a 18 ACR unit), best regards, Rob.
'68 S4 DHC
fatboyoz
PostPost by: p.faurie » Fri Apr 05, 2013 9:10 am
I think your boys will have a hard job on their hands in the second leg,unlike my managerless lot
sorry about the highjack but couldnt help getting one over the old enemy :
phil cfc CAREFREE
p.faurie
PostPost by: 512BB » Fri Apr 05, 2013 9:25 am
I have to agree Phil, specially if your best player has a broken ankle and your other whizzkid on the other flank keeps making a ham of his string. We shall see though.
Sorry Rob, hijack and all.
Leslie
PostPost by: bertavfc » Fri Apr 05, 2013 8:20 pm
Hi, many thanks for that information, will order those parts ASAP!, no problem Lesley there's always a spurs fan about, when you've won the European cup your more than welcome to criticise Villa (only kidding), cheer's, Rob.
bertavfc
First Gear
First Gear
