Early Elan coupe license plate lamp
I went to install my new license plate lamps on my early Elan coupe and the did not fit. The rectangular holes are too small for the lamp bases. I looked in the parts book and it shows a different part. Does anyone have a picture of what I should be looking for and where I can get them?
Bob
Bob
- zog
You might try this one, Bob. Made by Hella, although it might not be exactly what Lotus used for your early Elan Coupe.
http://www.amazon.com/dp/B000CHPCXQ/ref=pe_vfe_td1
Steve in Ohio
Steve in Ohio
- sveris
Bob,
The licence plate lamp that you show in the photograph looks just like mine (S4 fixed head 1968). Mine are Hella, but I am not sure of the number. Both lamps are the same, but the numbers on the outside of the boxes are different. Both lamp lenses have the following marks
K 12813
E1 (in a circle)
12958R4
HLO (Or HL0)
I went out to the garage to see if they fit. They do, perhaps that one of the differences between an S4 and your car.
I have rummaged through my paperwork and found the invoice that shows Part No 2K 001 378-041
I assume this is the Hella part number.
Richard Hawkins
K 12813
E1 (in a circle)
12958R4
HLO (Or HL0)
Richard Hawkins
- RichardHawkins
sveris wrote:I have rummaged through my paperwork and found the invoice that shows Part No 2K 001 378-041
Google shows this part as available from here http://www.sparepartstore24.co.uk/933534-hella
The drawing looks like the lamp.
I also found them on ebay for about $12 and $195 shipping to the US. Yikes!
Unibrain - Second Gear
I covered the license plate light used on later cars in this posting - http://www.lotuselan.net/forums/electrical-instruments-f38/source-license-plate-lights-sprints-t27227.html
Isn't Bob's point that this light too large for his early car?
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I have seen a flat lense light .... checked the parts manual also.
The later lamp as shown originally had a different terminal arrangement - Having one 'horizontal' terminal and using the mounting screw for the other. ie one blade and one eye.
- AHM
