S4 headlight switch bezel cup
Hmmmm thinking maybe cortina wiper / washer switch, where the recess allows for the washer pump to be pressed in? Would need to see both side by side however
- robertverhey
I just looked at my S1-S2-Coupe parts book, which is a great place to look for sources of Elan parts. The cups were not even pictured. This vacuum switch was used on all Elan models. Interesting that the switch itself is a Lotus derived number, but the knob has a 109E Ford number, leading me to surmise that the cups and slotted nut were part of the switch. I do know that the nut is similar but larger diameter as those used on Lucas push-pull switches. I had misplaced the nut on my SS while it was recently out of the car, and I checked every Lucas switch I had for a replacement nut. I gave up on the replacement when I found the original.
I made a pair of cups to locate a Lucas push-pull switch in the dash of Lotus 20/22 Formula Junior. They are aluminum, made on my lathe.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Appreciate it guys. I checked my Cortina sources but unfortunately these are unheard of. My S4 parts book doesn't show these either but having a Federal Sprint, I"ve come across Europa stuff in my car quite often. Perhaps if anyone has a Europa parts manual, I'd appreciate it if you can tell me if these parts are listed.
Greg Z
Greg Z
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
I found the cups. They are the same as used on early Elan windhield wiper switch with the manual washer pump. I could not find the correct chrome nut but I have a knurled one that fits and you can cut a groove in it. Groovy baby! I'll mail it out tomorrow.
- zog
