Rocker Switches
PostPost by: phillipcoombs » Tue Feb 05, 2013 4:28 am
Does anyone know of a good way to clean the oxidation off the rocker switches? Mine are looking faded and grey. I heard using silicone brake fluid would clean them but I tried it with little results. I could always scuff and paint but I was hoping someone had a better way.
phillipcoombs
First Gear
First Gear
PostPost by: DavidLB » Tue Feb 05, 2013 8:23 am
If you search the forum there is a method using a dye. I used this on mine which worked
DavidLB
PostPost by: fatboyoz » Tue Feb 05, 2013 1:04 pm
Phil,
Several coats of Armorall will bring them up like new. Reapply once or twice a year.
Colin.
phillipcoombs wrote:Does anyone know of a good way to clean the oxidation off the rocker switches? Mine are looking faded and grey. I heard using silicone brake fluid would clean them but I tried it with little results. I could always scuff and paint but I was hoping someone had a better way.
'68 S4 DHC
fatboyoz
PostPost by: sveris » Wed Feb 06, 2013 6:20 pm
If you're interested in new replacements, I can offer a solution of sorts. Years ago, I found a batch of surplus switches with smooth, shiny black and ribbed beige rockers. Virtually identical to our OEM ones - perhaps .5mm wider. All you do is swap the black ones for the beige ones and you're good to go.
First Elan dashboard I restored was for an S4 Sprint which is now in our local British Museum of Transportation.
I can probably put together a few more sets with the switches I have on hand.
Steve in Ohio
sveris
Users browsing this forum: GLB and 7 guests
