Lotus Elan S2 Headlights
PostPost by: Etienne 7 » Mon Jan 28, 2013 9:07 pm
Hello all,
My car is LDH but will stay on the british side of the Channel for a little while and I am planning to swap the headlights for some RHD ones.
According to the Robinshaw/Ross book, the reference for S1-S3 are model F700, part number 58683D/E.
Lots of classic cars have F700 headlights on, but with different references.
Any idea what the reference means? Or what the differences could be between two references? I could be offered some Morris Minor RHD lights but I have no idea if they fit and/or what the different is.
Thanks for your replies,
Best regards,
Etienne
Etienne 7
PostPost by: 1964 S1 » Mon Jan 28, 2013 11:19 pm
Greetings Etienne,
I'm guessing the Morris headlights will work fine. Are you sure you don't already have RHD lamps in the car? I guess the difference is the aim, and high beam location but I'd think you could adjust LHD to be nearly RHD using the adjustment screws on the bezel holding the light in.
If you park in front of a wall and flip from low beam to high beam, which way does the high beam move L or R?
Good Luck, Eric
1964 S1
PostPost by: Etienne 7 » Wed Jan 30, 2013 9:57 am
Thanks for your answer Eric!
My car is an original LHD and spent all its life in Switzerland, so the lights are LHD.
My plan is to put the car on UK registration plates (easier for insurance reasons) so I will have to pass the MOT tests and that can be done only with a proper set of RHD headlights.
Thanks again,
Etienne
Etienne 7
PostPost by: terryp » Wed Jan 30, 2013 10:57 am
Just be carefull that some have side lights , some don't
Terry
terryp
PostPost by: Etienne 7 » Wed Jan 30, 2013 11:18 am
Hi Terry,
Good to see you here :D ! Thanks for the advice, i'll keep an eye!
All the best,
Etienne
Etienne 7
