Lumenition Module Location
PostPost by: AHM » Thu Nov 15, 2012 6:49 pm
Hi All,
I am just about to fit Lumenition Optronic ignition to the S3 (the S4 already has it).
On the S4 the module is mounted on the baffle plate next to the rad.iator. The S3 with its wider radiato r doesn't have the end plates. Where should I mount the Lumenition module?
Simon
AHM
PostPost by: AHM » Fri Nov 16, 2012 11:48 am
Anyone with Lumenition and a wide radiator?
AHM
PostPost by: elanman999 » Fri Nov 16, 2012 12:36 pm
Simon,
As it's an after market part it's where ever you can fit it. But I mounted mine on the inner wing just below the air trunking.
Here's a pic.
IMG_0110rs.JPG and
elanman999
PostPost by: AHM » Fri Nov 16, 2012 7:10 pm
John,
Great, Thanks!
I was looking at putting it there, particularly as it is second hand and the wires are a little short!
I was concerned about it getting too hot - Clearly it is ok
many thanks
Simon
AHM
PostPost by: elanman999 » Fri Nov 16, 2012 7:29 pm
Simon,
Well mine worked OK for about 7 years.
Now gone EFI. :D
elanman999
PostPost by: AHM » Sun Nov 18, 2012 2:23 am
Well I got it all connected and finished at 1.30 am - (My neighbours must think I'm crackers!)
Turned the key - Two shotgun backfires ... That'll please em!
Timing 180 o out! I'll do it later in the morning!
AHM
