indicator and hazard relays
Try these......
http://www.autoelectricsupplies.co.uk/product_list/35
http://www.autosparks.co.uk/index.php?cPath=773
http://www.vehicle-wiring-products.eu/V ... ashers.php
http://stores.ebay.co.uk/Auto-Electrica ... 581&_pgn=2
S4 DHC
S4 DHC
- oldelanman
Thanks Roger, lots of choices!
This got me doing a bit of an internet trawl and lead me to a Triumph Stag site. A guy on there was suggesting there is a single electronic modern relay which does both hazard and indicator functions. Does anyone know about whether this is a possible conversion on a +2?
Jon
Jon
- jono
RogerFrench Posted this topic on the ganged DB10 relay a year and a half ago. This is what I plan on with the stop, brake and directional lamps on the Sow's Ear Elan. So far I have only the wiring done, I don't believe that the wiring needs to be changed other than inside the passenger compartment. This looks to be a very nice solution to the limited rear lamp visibility that the early Elans (type 26, 36 and 45) suffer from and may prevent others from using you as a bump stop while slowing, stopped or turning.
Gary
This is a direct link to the .doc file.
download/file.php?id=11645
original topic is here
post133182.html
Gary
post133182.html
jono wrote:Thanks Roger, lots of choices!
Jon
Sounds like you have a solution, but in answer to your question I used one of the combined relays during my re-wire. I required three additional block type relays to replace the functionality of the modern hazard toggle switch that is used in a modern circuit. I did it this way so I could use the stock dash switch. So in my case it all works, but is not a simple retrofit. As I had the dash out and was replacing the wiring completely with relays for other stuff it seemed the way to go.
Stu
1969 Plus 2 Federal LHD
