Lucas Voltage Regulator RB 340
I have some charging problems on my S4 Elan, in that the ignition warning light flickers at low revs and on occasion the battery is flat even after a run.
The output from the dynamo seems fine, so the easy, cheap fix is to swap the Lucas RB340 voltage regulator.
There seem to be several versions of this. I am not clear whether I need to worry about this, as visually they seem identical.
Does anyone know the answer?
Peter
Peter
- pburgess000
Hi Peter
You need to take the black plastic cover off and count the bobbins.
RB106/2 (2 bobbins) on my +2 with spade connections. 12 volt, 60 ohms and 22amp setting.
Would this be the one you need?
http://www.ebay.co.uk/itm/NEW-Voltage-r ... 617wt_1037
Jason
Jason
Jason1 - Coveted Fifth Gear
Thanks guys, some good tips here. I shall investigate under the lid.
Peter
Peter
- pburgess000
According to the AES site, the RB340 3 bobbin design comes in three different maximum currents, of 11 amps, 22 amps and 25 amps. I believe you should use the 25 amp version, but may be wrong. Presumably depends on the dynamo it's paired with.
The RB106 2 bobbin model is an older design in a different case and i think it is 22 amp. My recollection is that the third bobbin of the RB340 is for current regulation, and it gets a bit more out of the dynamo than the RB106.
Personally, i find these difficult to set up right. the adjustments have to be made quickly, before the unit heats up, so you may have to have several goes at it, with a suitable cooling off period. So I'd be inclined to put in a new one, bench set and guaranteed.
- ricarbo
Thanks everyone. As a brand new replacement is under ?25, it seems a worthwhile route to go. I wil let you know if it makes a difference.
Peter
Peter
- pburgess000
