side lights flashing
PostPost by: Crusty » Wed May 16, 2012 10:26 pm
After about 10 seconds the side lights start flashing quickley.
I am in for a service nx month ill get it sorted then but out of intrest what causes this.
>.....ELAN 1969 S4 SE COUPE.....<
>...SEE YOU ON THE FLIP SIDE...<
Crusty
PostPost by: elansprint71 » Wed May 16, 2012 11:05 pm
10 seconds from when/what?
PostPost by: AHM » Thu May 17, 2012 12:19 am
Unlike my indicators!
The MOT man advised me that they were a little slow ? they are supposed to flash 100 ? 120 times a minute....?I?m not going to stand here counting them, but you need to investigate?
AHM
PostPost by: ricarbo » Thu May 17, 2012 9:43 am
low load on the flasher unit, usually bad earth at lamp. Lamps are for lighting, bulbs are for gardens.
richard
ricarbo
PostPost by: fatboyoz » Thu May 17, 2012 11:20 am
Crusty,
Are you referring to side lights (parking lights) or indicators?
Colin.
Crusty wrote:After about 10 seconds the side lights start flashing quickley.
'68 S4 DHC
fatboyoz
PostPost by: nebogipfel » Thu May 17, 2012 1:24 pm
Not really sure what you mean? But if the side lights are flashing when you operate the indicators it is likely to be bad earths to the indicator lights/lamps/incandescent devices. :wink:
nebogipfel
PostPost by: ardee_selby » Thu May 17, 2012 2:51 pm
nebogipfel wrote:Not really sure what you mean? But if the side lights are flashing when you operate the indicators it is likely to be bad earths to the indicator lights/lamps/incandescent devices. :wink:
I suspect you are correct. Have had the same problem and not just on the Elan
(Bulbs have filaments, lamps have wicks and lights are bl**dy offal... :roll:)
ardee_selby
PostPost by: Crusty » Thu May 17, 2012 5:07 pm
fatboyoz wrote:Crusty,
Colin.
Parking lights only ..
Crusty
PostPost by: ardee_selby » Thu May 17, 2012 5:35 pm
Colin.
Weird things can happen with poor earth returns in the wiring system. Could it be interference with the headlamp flashing system? (assuming it's still wired so they come up flashing). Do the parking lights keep flashing after the headlights have been switched on?
ardee_selby
PostPost by: nebogipfel » Thu May 17, 2012 5:41 pm
ardee_selby wrote:(Bulbs have filaments........
I'm glad you're not our gardener (not that we have one of course unless you count SWMBO)
and there's nowt offal about my lights :lol:
nebogipfel
PostPost by: Crusty » Tue Jun 12, 2012 6:43 pm
I did not know.. when the lights are up and you have only got the side lights on the headlights flash to say"we are not on", or "put us down" if you only want the side lights on ,clever. Ive never noticed and ive had the car 2 years..
Crusty
PostPost by: simonknee » Tue Jun 12, 2012 6:58 pm
I always thought this was a feature to allow you to flash oncoming traffic to warn them of hazards/accidents/speed traps whilst only needing one operation rather than two. Otherwise why not just use the relay to turn the lights on when they pop up? Least ways that was what I used it for in the short year I had a +2.
ricarbo wrote: Lamps are for lighting, bulbs are for gardens.
. erm, lightbulbs, erm, shouldn't believe everything your dad tells you... oh no look he's not wrong http://www.instructables.com/id/Light-Bulb-Vase/ they do grow flowers!!!
Simon
Simon
'67 S3 FHC 36/7002
'69 +2 50/1370 (stolen '00)
simonknee
