front sidelight fitting
Just done a test fit of the front sidelights and they look ok. But there is a gap along the side on of them and whe you look closely you can see inside the front of the car. Is this normal, I checked the manual and the archives to see if there should be a gasket there but it seems not.
Ta, Chris.
Ta, Chris.
tcsoar - Third Gear
The front sidelights are 'handed', but the differences are quite subtle. Are you sure you have the correct side on the correct side.
Roy
Roy
Roy Gillett - Second Gear
There's always been a gap on mine too,that is until I filled it with clear silicone,looks better...
