mysterious switch
Franck,
Should be the same as the two seat Elan. It is an alarm/immobiliser. When selected ON, it bypasses the coil feed and supplies power directly to the horn circuit. If the ignition is then turned on, the engine will not start and the horn will be activated.
Colin.
Colin.
spridget wrote:I?ve just discovered on my glove box a little switch on the right side. So I wonder if this kind of equipment was originally fitted or if it?s an aftermarket and what it is use for !
A thought ?
Franck
'68 S4 DHC
- fatboyoz
isn't it great to make those little discoveries ?
next you'll be wanting to see if you can get it to work!
Someone mentioned in the forum this week that working on elan door internal mechanism was the worst job .
I reckon acessing and fixing this little switch's internals & wiring comes a close second
RichC
RichC
RichC - Fourth Gear
oh, and before i forget .. the first outing in our +2 with local lotus club involved an incident with the switch.
I'd forgotten about the switch ( which I'd flicked up when we parked for lunch ) when we went to leave and I turned the ignition over and over and over & over . Must have been there cursing and swearing for 5 minutes before I remembered!!!!!! A very embarrasing 5 minutes ...
motto of story is :
take care with throwing switch because if you don't do it far enough it wont complete horn circuit (which will remind you it's on!), however you will have moved switch far enough to break ignition circuit
motto of story is :
RichC - Fourth Gear
Or Franck, seriously consider getting rid of this feature by wiring around it. We also had an incident similar to above, but the horn relay was trying to activate but not enough juice to blow the horn. Whole story involved lots of hassle, hitch hiking, etc.
The slide switches and their connections (soldered?) are prone to failure after so many years, and if someone bumps it putting stuff in the glove box....
Many folks have installed a battery cut-off switch for storage which works well as a sort of immobilizer function anyway.
Cheers!
Cheers!
Stu
1969 Plus 2 Federal LHD
RichC wrote:motto of story is :
Quite so.......throw it as far as you can !!
S4 DHC
S4 DHC
- oldelanman
Many thanks all for your replies
I was very far to imagine a so complicated alarm !
I tried it this afternoon, It doesn?t work; probably the wiring had been modified.
You?re right RichC, it?s very great to make these discoveries ! It?s a pleasure to better know the car, even I?ll probably throw this switch far away !
Stu, a cut off switch has already been installed; so this switch is no longer needed.
Thanks again, for your precious advices
Franck
Franck
50/0302 +2, Frogeye
spridget - Second Gear
PS... I'm with the man on the door internals .....
Ah! That little switch eh? Seamed like a good idea at the time I bet. The battery turn off switch is a great alternative.
Go Buy if you don't have already...
Alex B ..........
Alex B ..........
Alex Black.
Now Sprintless!!
Now Sprintless!!
