Advice needed on plunger door switch
Over the years the little plunger switch in the door jamb that operates the interior light has finally worn a hole in the door frame. I am looking for the best way to repair this. I could just fill the the hole, I could fit a piece of aluminium as a strike plate. Is there a replacement plastic switch type that could be used. I'm not too precious about original equipment so am interested in what others have done?
many thanks,
Colin
many thanks,
Colin
1971 +2S 180/5 Spyder Zetec
- spyzee
Colin
I've fitted a couple of chrome blanking plugs to act as striker plates for the switches...
P.S. can you delete the other post?
P.P.S.
One for the interior light ,one for the "you've left your lights on,idiot"
P.P.S.
Are the +2 switches more aggressive than the 2 seater ones then? Wearing a hole in the door where the switch hits isn't something I've ever had a problem with. A couple of years ago though, when I replaced the door switches, I used some little plastic caps to go over the end of the plungers - mainly to adjust the contact point but the paint on the door is still there.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
