Federal S4 headlight operating mechanism.
So the car is in a thousand pieces and despite taking pictures and keeping notes I have missed something. How is the operating tube (single failsafe vacuum operated) mounted? Do the 1/4 20 hex bolts go through the headlight pod then through the bobbin and then into the end of the operating rod so it pivots on the bolt? Is there a bush or something put over the bolt to make it the same size as the hole in the tube?
David
David
- dpchamp87
The operating rod goes into the headlamp bucket. The 1/4x20 hex bolts (actually called anti-rattle joints) are attached to the very bottom of the headlamp bucket and the second one to the rod itself, connected by the threaded link. I'll make a scan of the parts list and drawing and put it up or PM it to you later today.
Bob
69 S4
Bob
69 S4
- m750rider
Hi David
There is some info that I posted a while back on the non-failsafe vacuum system but much of may be of use to you.
elan-f14/vacuum-headlamp-actuators-non-failsafe-t21397.html
Gary
Gary
Users browsing this forum: No registered users and 59 guests
