rev counter...
PostPost by: rocket » Sun Oct 31, 2010 6:46 pm
Hi all,
Usual problem with needle bouncing up and down.Always had this but noticed that when i put thumb pressure onto fuse pushing it into holder the needle dips ,always believed electronic ignition was causing problem but???
rocket
PostPost by: bob_rich » Sun Oct 31, 2010 8:13 pm
hi
If pushing on the fuse makes the needle drop (I assume U mean goes to zero rpm ) then a dodgy connection may be the problem. with the RV1**** tacho's some electronic ignitions don't work but that would show up when it was installed. If the fault has suddenly appeared may be the dodgy lead or the tacho could have a internal fault. Could be the +12V feed to it but should not be the current lead from ignition to coil as that would stop the ignition.
hope this helps best of luck
Bob
bob_rich
Users browsing this forum: No registered users and 57 guests
