Refurbishing rocker switches
I've looked back and the Sue Miller tip seems to be polish them up with Silicon brake fluid. Has anyone done this and got experience of how long it lasts?
Are there any other patent methods for freshening up the old plastic and getting them black again? I've just tried Duraglit metal polish and it does a reasonable job but I've got the switched out of the dash and I'm looking for a reasonably long term solution.
I'm also hoping the topic title will make it easier to find in future.
thanks
thanks
- mikealdren
Mike,
I had the same situation myself. I wasn't convinced that any of the polish/silicon fluid solutions would last so I bought rocker switches from Pat Thomas at Kelvedon Motors and had a local electronics shop put the new rockers from the switches onto my existing ones.
Pat has/had a box full of Lotus rockers but as I only wanted them for the plastic bit it didn't matter which ones he sent me.
Of course,this only provides the answer if you have the dash out of the car.
Might help,
Martin B
Might help,
Martin B
- martinbrowning
Mike,
I have been using Autoglym vinyl and rubber care to maintain the black look and I have got to say that I am very pleased with the result, a quick spray each time the interior gets cleaned and it lasts between cleans, dash last cleaned before summer this year and they still look fine!
- DUKE
I bought a bottle of Plastic Trim Wax from a local parts shop to make a good job of tarting-up the external plastic bits on my wife's old Fiesta. I tried it on the rocker switches and they looked like new.
I guess they stayed that way for about a year before I did them again. Simply apply it, leave it to dry, and polish it off. You don't need to be that careful with it as it does not stick to the facia.
Brian Clarke
(1972 Sprint 5 EFI)
(1972 Sprint 5 EFI)
bcmc33 - Coveted Fifth Gear
I've got the switches off the dash in full (well autumn) sun in the conservatory so I'll try an experiment.
I've got shoe polish, silicone vinyl polish and Duraglit as we ll as chrome cleaner and other abrasive cleaners and polishes.
Keep the ideas coming and I'll photograph and post the results.
- mikealdren
Mike, I have good shiny rockers on my switches, all except two off. I suspect that the switches were replaced last time the dashboard was also replaced (prior to my ownership).
The two off dull oxidised switches also appear to be of a slightly smaller rounder shape but I think these are original. I'll post a photo later showing the difference. Anyway, because if the difference, the old switches clash with the new so I spoke to the storeman at Paul Maty. Outcome is that that they stock many of the later Plus 2 and Sprint rocker switches (in the slightly larger replacement form)
Gerry
Gerry
- gerrym
Hi Gerry,
Unfortunately the replacement switches are expensive if you need to replace them all and replacing the odd one ill only show up the others - even if they are all the same profile.
I think there's a market here for someone to manufacture the plastic rockers. The switches are easy to disassemble and it's the plastic that fades over time.
I'm fairly confident that I can resuscitate the plastic by the various methods I'm trying, the real question is how long the solution will last. Hence my experiment which I'll start this weekend.
If the Rustins plastic finish arrives, I'll start refinishing the dash too.
- mikealdren
Seriously guys, I get this happening on the rockers on the 7. As they are open to the elements and the sun in particular they do go a lovely shade of grey rapidly.
Cheap and cheerful "Back to black" found in any accessory shop does the job. Just as previous poster said, apply it, leave to dry and buff up..............seriously works better than all the more exotic compounds I've experimented with I promise you.
Kenny
Kenny
- kenny
I have tried cleaning the rocker switches with silicone brake fluid and- much to my delight, i have to say that it works better than you could ever imagine.
I met Mick Miller once and spent a couple of hours chatting with him about Lotus cars.
Mr Miller is a man I hold in high regard and it no real surprise that his silicone brake fluid tip works like a charm.
Sadly Mick is no longer with us, but he really did know his stuff.
- paul_adamson
