federal side marker light
Hello,
someone wrote in this forum regarding the wing side repeater light for the correct posision, indicating the measures.
Could any federal elans print owners do the same for the rear side marker lights? for the front it is easy becouse the federal bumpers has the hole for the light, but on the rear area no reference. Distance from the bumper and from the wheel or the corner of the body...
My car was federal but someone in the pust converted in european and now is a mix or a messe...; I am restoring the car slowly slowly in order to go back to the origina federal version, except the engine with weber carbs (more efficient!!) and the rear lights that are red/amber lens with two bulbs (tail and stop).
Thank you to everybody,
Umberto
elan sprint 7108000193K federal[quote][/quote]
Umberto
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
Hello Umberto;
Photos of the LH side marker. Mine are not level with the ground. The lower RH corner meets the bumper recess about 4" back from the bumper end. Hope this helps.
Phil
Phil
Phil
1968 S4/SE FHC 36-7936
- pamitchell
Hello Umberto
Mine are reflectors ( no light).
Phil
- pamitchell
Hello, Umberto, this might help:
The distance from the rear of the body to the rear edge of the lens retainer is ~20.1cm, following the bumper reveal to the vertical line from the retainer. The distance from the bumper reveal to the rear lower edge of the retainer is~2.5 cm. The distance from the bumper reveal to the front lower edge of the retainer is ~3.3cm. Measurements are approximate.
By the way, the front of the car is on jackstands so the car in relation to its surroundings is lower in the rear than it would normally be.
Best,
Best,
Ernie
Florida, USA
Florida, USA
elanern - Second Gear
Just measured mine and came up with the same measurements, although mine seems to be pointed in the opposite direction? Dan
Hello and thank you for the info.
could anyone to check hot the wire of the front side marker goes through the body? In my ex-federal I don't see any holes on the nose of engine bay; may be in the past someone closed the holes by fiberglass...
any pictures are helpful as usual...
Thank you,
umberto
Thank you,
umberto
Umberto Ferrari
Modena - Italy
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
Hi Umberto
mine are reflectors only.
Phil
- pamitchell
Phil,
thank you for the info but I remember your pictur. i assume that yours are not original. from the spare parts list and other book elan was with Lucas side markers lights, the same as Europa.
Umberto
Umberto
Umberto Ferrari
Modena - Italy
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
The front sidelight attaches to the front bumper and there is a hole in the body and bumper that the wiring feeds through. You need to remove the front bumper (1 bolt at each end and 1 in the middle) to install the sidelight. Dan
When did side marker lights become illuminated for USA cars? The build date on my S4 was Oct 68.
Phil
- pamitchell
Mine was built in may 1970 and they light up.
Dan
Dan
I am completely confused by this (being English!) My Federal S4 is a 1969
I have no side markers and Amber / Red rear lights, although these were replaced.
I have small side lights at the front at the side of amber lensed indicators.
I do have a new all red rear lens but would need another.
The question is what should I have and how should they work?
Terry
Terry
- terryp
sorry for the double post. see explanation below on the two pictures...
TED
- tedtaylor
Here's a twist to the story on federal marker lights...
I?m amazed at the variety and differences in what?s out there on parts, specifically with the front bumper. As I mentioned, not only is there the front license plate flat spot in some rarer (federal) models, apparently the side marker lights are mounted in varying positions as well. Some bumpers (non-federal) don?t have any flat mounting area for the side marker lights, thus they?re mounted above the bumper or a different marker light is mounted high over the fender arch.
What I have, again unique, is that my flat spot for the side marker light ?incorporates? the federal bumper mounting bolt hidden ?within? the marker light itself.
Is anyone familiar with this oddity?
Both my Elans are different by that 2-inch shift in the mounting. One Elan has the marker light just forward and separate of the bumper bolt and the other has the marker light rearmost and incorporates the bumper bolt within the marker light housing with a very flat head bolt. The actual fiberglass flat mounting area must then be different in the placement area for the light, thus the multiple styles and moulds for the differing bumpers.
Very Strange!
Very Strange!
TED
- tedtaylor
