Current Drain
PostPost by: jonnyconcrete » Wed Sep 22, 2010 6:48 pm
Here's an interesting one, I've just fitted a new fuse box and discovered that there is a steady 520mA flowing through my lighting fuse all of the time. The only circuits on that fuse appear to be the lights and the hazards. Any ideas?
jonnyconcrete
PostPost by: paddy » Wed Sep 22, 2010 8:18 pm
That's 6W which is a lot. Have you tried turning off all the lights in the garage and looking for what's glowing? :)
I wonder if it's the main beam warning light:
elan-f14/headlamp-relay-control-t16985.html
Paddy
1963 Elan S1
paddy
PostPost by: billwill » Thu Sep 23, 2010 12:24 am
Is there a hidden tracker box in the car?
Also your dash radio will take a bit of permanent current, but I doubt if that would be 6 watts.
PostPost by: Galwaylotus » Thu Sep 23, 2010 1:15 pm
Two thoughts:
Earth fault?
Is your ammeter calibrated/accurate?
'67 S3 SE FHC
Galwaylotus
PostPost by: jonnyconcrete » Thu Sep 23, 2010 6:56 pm
Aha!
Top tip...don't check your lighting circuit current drain with the doors open!!
:mrgreen: :lol:
jonnyconcrete
PostPost by: bob_rich » Thu Sep 23, 2010 7:25 pm
HI
with 520mA that is 6W so could be the glove compartment light or the boot light (if you have them) they can stay on if switch is iffy and U would not be able 2 C them. Agree with idea about ammeter car ammeters are very crude and really only good enough to say whether current is into or out of battery.
HOpe that helps best of luck
Bob
bob_rich
Users browsing this forum: No registered users and 52 guests
