Accelerator cable attachment
Hi all,
Can someone please see if they can post a photo of how the throttle/accelerator cable connects to a Stromberg carb TC? I need to see understand how the bracket that holds the outer cable I assume it is a bracket bolted to the cam cover.
Thanks in advance.
TonyW
Thanks in advance.
TonyW
Second childhood? no just an extension of my first.
- Tonyw
Tony,
Have a look at his thread, there's a pic of a cam cover showing the accelerator cable bracket.
http://www.lotuselan.net/forums/elan-f15/cam-cover-red-paint-t14754-15.html
S4 DHC
S4 DHC
- oldelanman
It's not just a couple of holes drilled right through the cover. The area under the bracket is machined flat and two blind holes are drilled into an area where an extra depth of alloy has been cast.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Tony,
It's a different cam cover for the Stromberg engine, the bosses for the bracket securing bolts are cast in. As you say I wouldn't want to drill and tap a standard cover, it's not flat and probably way too thin.
Stuart you beat me to it !
S4 DHC
S4 DHC
- oldelanman
Users browsing this forum: Mike133 and 18 guests
