Fuses again
Ok - I got the message
Thanks everyone
Robbie
Thanks everyone
Robbie
Be careful as many meters are limited in the amount of current they can pass. It's often a maximum 10 amps and mine is fused so anything over that means a fuse replacement. Problem is the fuse is an odd-ball sixe and type and not easy to get. For most loads it's ok but if you're trying to measure 17A it might cause problems. Some (expensive) meters can meaure inductive dc current using a clamp on current transducer (CT). A nice toy to have but I've never wanted to spend that much on something I'd only use rarely.
'67 S3 SE FHC
'67 S3 SE FHC
By George he's got it.
Because my best meter only goes up to 10 amps, I tend to use an old ammeter from a car to measure car currents, Not very accurate but good enough for that job.
Galwaylotus wrote:Be careful as many meters are limited in the amount of current they can pass. It's often a maximum 10 amps and mine is fused so anything over that means a fuse replacement. Problem is the fuse is an odd-ball sixe and type and not easy to get. For most loads it's ok but if you're trying to measure 17A it might cause problems. Some (expensive) meters can meaure inductive dc current using a clamp on current transducer (CT). A nice toy to have but I've never wanted to spend that much on something I'd only use rarely.
Good tip - thanks for that, I'd probably have ploughed ahead without thought.
Better get the manual out for the meter
Robbie
As other post suggest it pays to be careful with meter shunts especially in low cost meter. If you think the circuit might have a lot of amps that may go over the rating I use a simple home made shunt. It is based on copper wire so it is only moderate accuracy and use the meter on a low mV range.
The shunt is designed to be a nominal 1/1000th of an ohm so 50A gives 50mV. The one in the picture uses 4 square mm copper wire and the meter is connected across 0.23Metre length.
accuracy is good enough for a lot of tasks but if something goes awry it will not blow the meter up!
on each end I put a 1/4" fast on so i can plug it in to blade fuse holders. Any connections could be use on the end to suit the task in hand. To be really safe an in line fuse could be built in if required
I have used this idea on a number of higher currents including measuring starter motor current but for that the shunt was a short length of 15mm diameter central heating pipe
hope this helps
Bob
hope this helps
Bob
- bob_rich
