Mail order battery (UK) - recommended supplier
PostPost by: ppnelan » Thu Mar 25, 2010 11:06 am
I have just bought a replacement battery for my Elan S4 from Tayna Batteries - the heavy duty (higher CCA) type 015 with round terminals. I use the same type in my +2 - common parts means it is easy to swap in an 'emergency'! :wink:
It has a flat top with the old style individual vent plugs (not as shown on the website), which means access to the terminal clamps (negative earth) is now easy/possible with the battery installed - see photo. Excellent mail order service from Tayna - they emailed a tracking number so I could see when it would be delivered (in a day or two), and it was well packed (rubber bungs replaced the vent plugs to minimise leaks, wrapped in a thick plastic bag, then well padded with polystyrene in a box). And all for ?54 ! :D
The previous one has lasted 4 years of all-year-round use & abuse, but now struggles to provide enough starting current. It came from Halfords and was around ?45 so I was shocked to see their current price is now ?73 :!: :shock:
:arrow: Matthew
Battery_015_in_ElanS4.jpg and
ppnelan
PostPost by: john.p.clegg » Thu Mar 25, 2010 11:26 am
Matthew
Can you post the size of it? Physical and Amp/Hr
John :wink:
PostPost by: Frank Howard » Thu Mar 25, 2010 2:29 pm
Matthew,
You can probably order it with the posts reversed which in turn would give you even better access to the terminals. Here in the states, I find that any "Group 51" battery will fit so I have one in both of my Lotuses.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: ppnelan » Fri Mar 26, 2010 9:46 pm
john.p.clegg wrote:Can you post the size of it? Physical and Amp/Hr
John, the following details are on the website (click the 'Specification' tab):
Capacity - 42Ah
CCA(SAE) - 320A
Dimensions(mm) - 245 x 135 x 200
:arrow: Matthew
ppnelan
