Oil pressure gauge feed pipe S3
PostPost by: badback » Mon Feb 15, 2010 11:57 pm
As I seem to have lost / misplaced the original oil pressure gauge feed pipe for my 1967 S3 Elan renovation project my question is was this pipe plastic as on the S4s or did the early cars use a copper pipe
badback
First Gear
First Gear
PostPost by: Elanintheforest » Tue Feb 16, 2010 7:25 am
It's a kind-of plastic/nylon on my S3 which come to think of it, after 43 years, is a bit of a worry!
PostPost by: Galwaylotus » Tue Feb 16, 2010 7:51 pm
I wouldn't go with either plastic or copper. The latter can work-harden and crack over time. On my Mini I installed a Goodridge hose in -4 size (I think) and the response to pressure changes is terrific.
'67 S3 SE FHC
Galwaylotus
PostPost by: bcmc33 » Tue Feb 16, 2010 9:54 pm
I bought a new one from Paul Matty recently in response to a friend reporting his plastic pipe becoming brittle over the last 40 years.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: badback » Wed Feb 17, 2010 12:01 am
Thanks all good advice will get a new one from Matty
badback
First Gear
First Gear
PostPost by: oldelanman » Wed Feb 17, 2010 9:01 am
If you need another option these people do all types.
http://www.speedograph-richfield.com/html/oil_pipe_lines.html
S4 DHC
PostPost by: badback » Thu Feb 18, 2010 9:39 pm
Thanks Roger I had not thought of speedograph I used them some years ago for gauges and cables
badback
First Gear
First Gear
