Electric water pumps
With the convenional pump, the heater circuit is in parallel with the radiator circuit - so the heater acts like a second radiator, and dissipates heat from the engine. The bottom heater hose attaches to the front cover on the inlet side of the pump.
When an electric pump is fitted, it goes inline in the bottom radiator hose. This now means that the heater's bottom hose is on the outlet side of the pump, so the pump will then tend to push water through the heater in the opposite direction - which by itself isn't a problem, except that the circuit through the heater is then in parallel with the engine, so a fraction of the flow bypasses the engine entirely.
The solution is to relocate the heater bottom hose - blank off the intake on the front cover, and attach the heater hose to a new tee on the inlet side of the new pump.
Paddy
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Users browsing this forum: No registered users and 49 guests
