Ignition timing taboo
I've always had a bit of a mental block with timing but reading through the archives here I think I have it sussed.
I've had a slight hesitation on pick up that may be due to timing. I've checked everything else
Now I know this will appear very basic to some but I've checked my timing with a timing strobe light at approx 750rpm and its about 8 degrees , if I want to try to advance a little say 2 degrees , which direction do I turn the distributor body and by approx how much i.e. as a approx measurement on the circumference of the body of the distributor.
Would 10 degrees be OK for Super unleaded + castrol additive?
Terry
Terry
- terryp
Terry,
To advance the timing 2 degrees, the distributor must be rotated 4 degrees clockwise or about 2.65mm. It's best to use a timing light.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Hi Terry
I run my Plus 2 130/5 with 10 degrees advance on super unleaded with castrol additive and have no problems at all. In fact a week or two ago the local filling station had run out of super so I was forced to fill up with normal unleaded. The car still ran ok
Andy
Andy
- andyelan
had also noticed the same sort of hesitation..
tried playing with the timing on my 30yo distributor without much sucess..
Then (for other reasons) fitted a distributorless system (based on megasquirt)..
And the hesitation went away..
I think the problem was caused by scatter at low revs with a worn dissy!
(now running at 10 degrees on super UL when I can get it..)
1972 +2S130
tdafforn - Coveted Fifth Gear
