Oil presure gauge feed
gsmith246 wrote:where the oil pressure gauge pipe should run. i.e. where should it pass through the bulkhead? Greg
Greg, you dont say if it is a Left or Right hand drive and I think they are different, here is a couple of pics of my U.K. Sprint (rhd) and you will see it comes through the bulkhead just below the solinoid.(the oil pipe is the one with a black plastic sleeve over it)
Hi Greg
This drawing should help, most of the stuff is the same for LHD or RHD except the speedometer cable and steering column hole.
Gary
The photo below is a S2 firewall and not exactly the same as the S4 but a lot of it is close. The drawing was done from a S4 as stated on the drawing
Gary
Hi Brian
maybe I should put my signature back on and add to it RHD or LHD
Gary
Gary
Greg,
Gary is correct. Below solenoid regardless of steering wheel position.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Frank Howard wrote:Gary is correct. Below solenoid regardless of steering wheel position.
Hmmm. On my LHD S2, the oil pressure feed goes through the firewall on the left side, above the control box and just outboard of the wiring loom - where Gary has the battery feed. (My battery cable is where he has the oil pressure line.) The exact location may have been shifted over the decades, but it has always been on that side as far as I know.
Andrew Bodge
'66 Elan S2 26/4869
'66 Elan S2 26/4869
RotoFlexible - Fourth Gear
Hi Neil
I converted your link into an image here on elan.net. Right click on the photo and triple click on properties. Then right click and select copy and when you post reply on elan.net click on img box above the text area and insert the copied link in between.
works sweet
p.s. - the drawing was done with both LHD and RHD Elans in my garage so when I converted the RHD to LHD I would remember where the stuff went. The hard part now is remembering where that scan of the drawing was filed. When I can find stuff from 15 years ago
p.p.s. - I think we are all saying the same thing, Greg and others that come here for a bit of info to help with there problems should be gracious enough that each and every person that has tried to help a perfect stanger and took the time from there own busy lives so that someone that needed a bit of help could get his or her Elan/plus2 back on the road the way it was built. When I see those same folks back here looking around at the replies and not clicking on reply to just say "Thanks" is a statement of why its hard at times to keep trying to help
Neil, thank you for your posts I appreciate them
Gary
works sweet
Gary
Hi Gary
Failed at the triple click when I had a go from this end on a PC
Neil
works sweet
Neil
- neilsjuke
Triple Clicking is probably dependant upon which Operating system your PC is using, and/or which browser.
All you need are the "Location" details of the image that can be found under the "properties" option, usually on a single right-button click when on the image. This entire line (starting with "http.....) can then be selected & copied as a cut'n'paste as Gary advised.
Rgds
Rgds
'72 Sprint
'72 Sprint
- richardcox_lotus
gsmith246 wrote:Thank you all for responses.
I must Neil your Flickr page is fantastic.
Thanks again
Greg
Hi Greg
Glad that all of us could help. When I see "thanks", I assume the question was answered. When there is another question, then I will answer that too if I can, and if there is more detail like S4 rhd with SE spec Stromberg head engine then I can say something that might be exactly what you are looking for. Details may be boring but the answer you get will likely be the one you need. When I see my Elan is broken, I just move along, but thats just me...
When there is no response I just don't know
Gary
Hi Richard
Depends on how the mouse is set up too, but windows98 is getting a bit old now but then again it does mail and web so for dial up its OK.
Hi Neil
http://www.flickr.com/photos/16638375@N ... 202952079/
I went to the failed link, that is url (i think) clicked on "all sizes" and then right clicked on the photo to get the properties.
which are
http://farm4.static.flickr.com/3499/376 ... 7332_o.jpg
and then I did the image button
and got the following
Gary
Speaking of locations of various items under the bonnet......... In reviewing many pictures over the past three years, the many locations of the coil is interesting. I moved mine from under the carbs, should the be a drip of fuel. However, the sparks generated by the distributor could still ignite any spurious vapors under the right conditions. Where did the coil originally mount?
Rob Walker
26-4889
Rob Walker
26-4889
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Thanks Gary have had a play in the test Zone
And have done it just need to remember how
Neil
Now i have got the hang of it here is another picture of the test tool (spot lamp bracket for the Cortina )
Open picture in Flicker,
Click on all sizes above picture
Grab picture url (2)
Return to Elan .net
Click on box img
Check that pointer is in the middle and paste
Simple
Well it is now
Neil
Neil
Return to Elan .net
Click on box img
Simple
Well it is now
Neil
- neilsjuke
