Otter switch connector
The cooling fan has packed up on my +2S130, I've purchased a modern one to replace it and plan to re-wire with a relay as it is more powerfull, the only problem I have is that the connector into the otter switch is missing (currently 2 dodgey crimp connectors are used to wire it in) has anyone found somewhere to buy the proper connector (I don't even know what it looks like!)
kevin
kevin
- kstrutt11
Kevin,
I tried to buy the "proper" connector. Apparently, the crimp connectors are the proper connectors!
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
I was sure I had seen a connector used somewhere on similar switches, trouble is most early 80's / late 70's leyland stuff is now rarer than the +2 !
In the end I have used crip on connectors and covered the horrible red plastic with black shrink wrap.
- kstrutt11
