Orange indicator repeaters
I didn't make a note of the postiion of the orange wing (fender) repeater lamps on my UK spec S4. The body shop of course filled in the holes so I need to redrill the holes in the correct position. Can anyone help with the dimemsions. Please note that I still have the original lamps which are smaller than the replacement ones that are available these days.
Keith Marshall
- saildrive2001
Mine are on a level with the top edge of the door aperture with the vertical centre line of the lamp 14.5 inches forward of the front edge of the door aperture. See pic.
S4 DHC
S4 DHC
- oldelanman
Thanks Roger. Looks like you are in the process of a full restoration like I am.
Keith Marshall
- saildrive2001
I'm new to the forum and was interested in this thread.
Could anyone tell me the name/source of the side repeaters shown in the picture above - Rogers - UK spec.
It must have the continuous chrome surround that goes into the cutouts where the screws go.
I've got one example, but need another to match - it has no markings/name on it.
It's NOT the Lucas L734, but I've been told that its a Lucas Sedan Part No FL155.
Is this correct?
Jonathan
Is this correct?
Jonathan
- foxoles
Thats a Sparto lamp.Same as the interior light with the white lens.
This repeater lamp is original fitment only to Sprints.They are now very hard to come by and unless you're a stickler for originality to be honest the lucas lamp is a better quality fitting.
Nigel Robertson
robcall - Third Gear
Not entirely correct, my 69 S4 SE also has the same repeaters which are smaller thatn the new ones available these days. If anyone knows a source for the smaller ones I would be interested as I need to replace the aluminium surround on one of them.
Keith Marshall
- saildrive2001
Hi Keith,
unfortunately the sparto lenses are no longer available.
I did my first resto in 1980 and I could only source the lucas type then!
The white/orange lenses are sometimes seen on ebay-the aluminium surrounds fit both.
My reference was from Brian Bucklands manual so i did a bit of digging
Robinshaw/Ross S3-lucas 52813a S4/Sprint lucas fl155 or sparto
Period photos-
Motor test S4 1970-looks to be sparto
Rindt Sprint(an S4)-sparto
lotus brochure-Elan S4(yellow dhc front/white fhc back) both-lucas
possibly a case of what was to hand for S4/SEs
Interestingly again according to Robinshaw/Ross the sparto interior light was present from S1-Sprint
Period photos-
Nigel Robertson
Hi Nigel,
Did you find out what other vehicle they were used on, there might be a chance that some are ina scrap yard somewhere.
Keith Marshall
- saildrive2001
Jonathan
Vehicle Wiring Products sell a similar thing to the Sparto that they call Torpedo Lamp, but clear lens only. Perhaps it could be tinted orange somehow. See their item M23, less than ?2 too.
Ian
Ian
1969 S4 S/E BRM DHC
- iancockshull
Ian,
That's a good lead. My lenses are ok it's just the metal trim pieces that are corroded & need replacing.
Keith Marshall
- saildrive2001
Keith-the only other vehicle I found with these repeater lamps was a-Europa-sorry
Ian-that lens may be worth a punt I wonder if they can get an amber lens?
Tamiya do a transparent orange paint-meant for plastic model cars.
this could be sprayed inside the lens for effect.
http://forums.evolutionm.net/evo-genera ... paint.html
http://www.tamiya.com/english/products/ ... t85003.htm
Nigel Robertson
