Stuck horn push
PostPost by: John Sharples » Sun Jun 28, 2009 2:56 pm
I can't remove the horn push on my Sprint. It is absolutley stuck - anyone had similar problem?
John Sharples
First Gear
First Gear
PostPost by: neilsjuke » Sun Jun 28, 2009 4:25 pm
Try pushing side to side round the clock and twisting dont pull
Neil
neilsjuke
PostPost by: Frank Howard » Sun Jun 28, 2009 4:27 pm
John,
I'm assuming you have the newer non-Chapman signature wheel with a horn push that is 3-1/4" in diameter. It should come off. Just pry it off.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: types26/36 » Sun Jun 28, 2009 5:09 pm
Frank Howard wrote:John,I'm assuming you have the newer non-Chapman signature wheel .
Did any Sprint have a " non-Chapman signature wheel" ............except for a after market non original wheel :? :?:
types26/36
PostPost by: elansprint71 » Sun Jun 28, 2009 8:29 pm
My 68 S4SE had a non-sig wheel, same wheel, just no script.
PostPost by: types26/36 » Sun Jun 28, 2009 8:38 pm
elansprint71 wrote:My 68 S4SE had a non-sig wheel, same wheel, just no script.
Yep....so did my 72 Europa but it wasnt a Sprint
types26/36
PostPost by: John Sharples » Mon Jun 29, 2009 8:54 am
neilsjuke wrote:Try pushing side to side round the clock and twisting dont pull
Neil
Neil - can you elaborate a bit? Do you mean push from the edge of the horn push to the centre? Twist in which way ? clock and anticlockwise? How does the horn push fit on the wheel? I presume it is an interference fit of some sort but what shape?
It?s a 72 Sprint with a signature wheel.
John Sharples
First Gear
First Gear
PostPost by: types26/36 » Mon Jun 29, 2009 9:17 am
If this is the wheel you have to just prise out the centre button and you can get to the nut.
HORN BUTTON 003 (Copy).JPG and
types26/36
PostPost by: neilsjuke » Mon Jun 29, 2009 10:44 am
Hi This is hard to explane you have 3 clips (Sprung) that go into the horn push and a earthing bar so you need to give it a twisting only a little bit / pulling pushing at 2/6/10 hours , I hope its not stuck due to a repair with some super glue.
Here is some pics of mine at the end of the set
http://www.flickr.com/photos/16638375@N ... 202952079/
Neil
neilsjuke
PostPost by: John Sharples » Mon Jun 29, 2009 10:47 am
types26/36/74 wrote:If this is the wheel you have to just prise out the centre button and you can get to the nut.
Great Brian - thanks. Clear now.
John Sharples
First Gear
First Gear
PostPost by: John Sharples » Mon Jun 29, 2009 10:55 am
neilsjuke wrote:Hi This is hard to explane you have 3 clips (Sprung) that go into the horn push and a earthing bar so you need to give it a twisting only a little bit / pulling pushing at 2/6/10 hours , I hope its not stuck due to a repair with some super glue.
Neil
Thanks Nei. Very useful set of photos.
On another subject, my gearbox is not quite central in the hole in the body (5th picture in your first set). Any thoughts as to why that might be?
John Sharples
First Gear
First Gear
PostPost by: neilsjuke » Mon Jun 29, 2009 11:31 am
Hi John
"On another subject, my gearbox is not quite central in the hole in the body (5th picture in your first set). Any thoughts as to why that might be"
If the engine/ gearbox mounts are ok and the body is on square then it may be the hole in the tunnel was drilled by Fred on a Monday on mine and yours was Sid on a Friday.
Neil
neilsjuke
PostPost by: robcall » Mon Jun 29, 2009 12:55 pm
I think you have to be specific which steering wheel you have.
The picture Neil provided is for the early wheel up to 1971.
The picture provided by Brian is for the later wheel-probably correct for your vehicle.
The hubs are totally different in construction and fitment.
Nigel Robertson
robcall
PostPost by: John Sharples » Mon Jun 29, 2009 3:19 pm
robcall wrote:I think you have to be specific which steering wheel you have.
Yep - mine is like Brian's.
John Sharples
First Gear
First Gear
