Oil pressure gauge connection
mart2elan wrote:At the engine side it is a conic fitting and on the gauge side it is flat with a little O-ring.
The engine end is conventional 1/8 BSP in which the fittings themselves make the seal without an intermediary gasket. The gauge end is a slightly odd 1/8 BSP arrangement in which both fittings have planar mating surfaces requiring a washer-like gasket. I have seen different materials used. Moss Motors sells leather washers for this application.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Thanks Marten and Russ.
Now that you mention a leather seal Russ, I seem to recall one of these being fitted when I pulled it apart all those years ago. A friend has donated a flat rubber washer from his Mecedes, pneumatic suspension rebuild kit. I'll see how that goes.
Colin.
Colin.
CBUEB1771 wrote:mart2elan wrote:At the engine side it is a conic fitting and on the gauge side it is flat with a little O-ring.
'68 S4 DHC
- fatboyoz
Users browsing this forum: rideaway and 45 guests
