Alternator wiring - only one output?
I have fitted a 45 amp Lucas ACR replacement alternator.
I've updated the wiring using the wiring diagram in the technical section with 8 fuses.
I've connected the alternator up as in the diagram which show a white [14] running from the alternator to fuse 6 which is the switched ignition circuit. I've connected this white [14] to one of the large spade terminals on the alternator, the other large spade terminal connects to the battey + wiring and I've run the small spade terminal to the ignition warning light.
But .... wired this way the ignition warning light comes on when the ignition switch is off, and the indicators also work despite the ignition being off - ie it seems the "switched" ignition circuit is being bypassed.. I think the 2 large terminals on the alternator are common so that 12v runs down the white [14] from the other large terminal that connects to the battery + circuit. Disconnect the white wire and all the electrics work fine and the ignition light only comes on when the ignition is switched on.
Is the additional white wire needed? I understand that the alternator needs 12v through the warning lamp circuit to get going. As far as I can see the white wire is pumping 12 volts into the switched ignition circuit but 12v is already being provided down the main output cable to the battery circuit.
Lotus Elan Sprint FHC 1973
RichardS - Third Gear
Richard,
From you description, it appears that you have three wires. The first one is white, the second one is white and the third one is unknown. Did the alternator come with a 3 wire pigtail harness? If so, what are the colors of these three wires?
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Frank
I've wired in the alternator as in the wiring diagram http://www.lotuselan.net/uploads/elan_m ... wiring.pdf
White [14] from large spade terminal to fuse 6
Brown/yellow [14] from small alternator spade terminal to ignition warning
Brown/White [84] from other large spade terminal to battery 12v +
The connection to the alternator spades is with a standard alternator plug.
Any clearer?!
Any clearer?!
I have never seen this diagram before. I studied it and concluded that you have wired it accordingly. I would look at the connection to the alternator and check to confirm that the white wire actually connects to the terminal marked "IG" on the alternator and the brown/white wire actually connects to the terminal marked "B" on the alternator.
I think you should switch the two above. White [14] should go from large spade terminal to battery 12v +. Brown/White [84] should go from other large spade terminal to fuse 6. Let us know if this works or if we should stick our fingers in our ears and wait for the explosion.
RichardS wrote:White [14] from large spade terminal to fuse 6...
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Richard,
Your alternator may look like a 3 terminal one as shown in the wiring diagram but as Neil says the 2 large terminals are connected internally, so it is really a 2 terminal type.
Just remove the wire from the large terminal to the fuse and you should be OK.
- alan71
Thanks everyone - confirms my thoughts and that my conclusions were concurred with! The main brown/white cable is a nice thick cable!. The "extra" thin white was pumping 12v into the switched ignition circuit and causing the problem. I will leave it disconnected.
Users browsing this forum: rideaway and 50 guests
