Sprint headlights closing
hi there,
Not sure if this is a simple problem, but my headlights are closing (72 Sprint) when i accelerate in any gear. Literally anything other than very mild acceleration is causing them to close up... and on lifting the throttle, they pop open again.
Any suggestions for cause/cure very welcome.
Best
Will
Best
Will
- WillB
One thing that could cause this is the one-way valve vibrating to engine revs(mine did) a quick solution is to put another in line with it.
Check the one way valve, its screwed into the end of the manifold then the vacuum pipe goes onto it. It should only pass vacuum one way.
Check out the "Headlamp" article on the Golden Gate Lotus website.
www.gglotus.org
Then go to "TECH" and check in the "ELAN" Section.
Kiyoshi
GGLC Webguy
www.gglotus.org
Kiyoshi
GGLC Webguy
khamai - Third Gear
Hmmm--Sprints theoretically should have the Failsafe System, which means they should OPEN when vacuum lost. Regardless - I had similar symptoms (except opened upon slight acceleration, and my one-way valve innards had vibrated loose. I simply unscrewed one end of the pencil shaped valve, put a dab of lock-tight onth inner threads and tightened the inner valve body a few turns until vacuum operation was restored. Voila! My valve was purchased from Bean -so if yours is different - look for a similar adjustment.
Good luck
Paul Zimmerman
65 S2 with converted Failsafe headlights
Good luck
Paul Zimmerman
- brassringfarm
M100 wrote: Mine is a very late 72 UK spec and its always been non fail safe.
Same here,mine is October 72 and also a non-failsafe.
Brian.
