Wiper Motor.
Hello.
I need to confirm the conections on the mulit plug connecter on my 1969 +2s wiper motor. At the moment i have this
position 1 black .(Earth)
2 Yellow/ black (Fast speed)
3 Red/ black
4 Yellow (slow speed )
5 Brown /purple. (12v feed )
Is this correct as i seem to be having problems.
regards Ian .
3 Red/ black
regards Ian .
- FEDUP
Acccording to my little diag it's
1 Earth-Black
2 Park-Black/yellow
3 Fast-Light green
4 Battery-Green
5 Slow-Yellow
but I have been known to be wrong..
1 Earth-Black
2 Park-Black/yellow
3 Fast-Light green
4 Battery-Green
5 Slow-Yellow
Hi Ian,
Hopefully this attached Word document might help... It did for me!
Alex
Alex
- Attachments
- Windscreen Wiper system.doc
- (76.5 KiB) Downloaded 726 times
- Alex
How do you alter the park position
Regards John 1969S4DHC
- triumphelan
triumphelan wrote:How do you alter the park position
John,
By "alter" do you mean adjust? If so, Alex is correct. On the other hand, if you are asking how to get the wipers to park on the opposite side, the (partial) answer is that you have to open the motor gear box.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Thanks Frank
I want them to park on the otherside,what sould I be looking for inside the box?
- triumphelan
Thanks Frank
- triumphelan
Hi John,
Refering to the attached file further up the discussion (exploded diagram on last page), you will need to take the cover plate (1) off and remove the large gear wheel (7). On the other side of this, there should be a pin which activates the park switch.
From this point it could be easy or difficult. Wiper motors have say a 110 degree rotation but you need to swap the end point of your travel. In effect, you need to remove the pin and re-fit it in an equal but opposite position on the gear. Lucas may have designed them with 2 pin positions to do this but I'm not sure.
All may become clear when you have it apart.....
Alex
Alex
- Alex
triumphelan wrote:I want them to park on the otherside,what sould I be looking for inside the box?
John,
Alex answered your question however there are two different styles of wiper gearbox. If you have the later style (and I believe you do), all you have to do is remove the gearbox cover, rotate it 180 degrees, and reinstall.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Frank
Just rotate "the cover" 180deg?
- triumphelan
John,
There are two wiper motor units; the DR3 and the DR3A. I can't remember which is which, but on one of them, you slaken the screws that hold the gearbox cover on and rotate the domed cover 180 degrees. On the other model, you remove the screws completely and open the gearbox. Then you relocate the crankpin 180 degrees either by moving it to the opposite side of the gear, or by flippig the gear itself (I can't remember).
Once you remove the wiper assembly from the car, it will be fairly obvious.
Frank Howard
'71 S4 SE
Minnesota
'71 S4 SE
Minnesota
- Frank Howard
Users browsing this forum: syrius and 28 guests
