head light relais connection
PostPost by: bengalcharlie » Sat Sep 20, 2008 8:26 am
can anyone help me explaining the following: in the wiring diagram the relais have 4 connections: c1 c2 w1 and w2.
My Hella relais shows 30 85 86 and 87. Does anyone know how I connect this??
Have tried it but relais makes strange noise so something is not right.
I am frustrated cause can not drive the car and spring has arrived!
Robin
bengalcharlie
PostPost by: types26/36 » Sat Sep 20, 2008 10:10 am
The connections in some applications are swapped with corresponding terminals but this should be O.K. for your car.
File0028 (Medium) (Large).jpg and
types26/36
PostPost by: bengalcharlie » Sun Sep 21, 2008 6:59 am
Many thanks Brian for this info, I will keep this with the wiring diagram and will connect the relais accordingly.
Robin
bengalcharlie
Users browsing this forum: No registered users and 41 guests
