busted dizzy
PostPost by: Robbie693 » Sun Jun 08, 2008 5:41 pm
Looks like my distributor has had a bit of bodging in the past - tried to fit a new cap today and a section of the body broke off with the clip on it! There are traces of what looks like Araldite around the broken area..
Is this something that can be economically fixed or do I buy a new one?
pics of the offending item:
bit.jpg and
diz.jpg and
Robbie693
PostPost by: cliveyboy » Mon Jun 09, 2008 6:47 am
The body is scrap, I would not even attempt to try fixing it.
Either swop your inners into another body or buy a new distributor.
Clive
1972 Elan Sprint FHC
cliveyboy
PostPost by: Alex » Mon Jun 09, 2008 12:17 pm
Hi Robbie,
Thats a dead distributor!
One trick that worked for me years ago, was to swap the internals into a housing off a Mini/Morris Minor etc. The casting is identical apart from having a vacuum advance. Fit your Lotus dizzy shaft, advance weights and springs and cam into the new housing, but use the contact plate off the donor dizzy. In this way, you can use the vernier adjustment which is part of the vacuum advance.
Alternatively, I've got a proper housing in my drawer here at work!
Alex
Alex
PostPost by: Robbie693 » Mon Jun 09, 2008 3:18 pm
Thanks guys - I feared as much.
I should have mentioned it is the 43D4 type. H&H can replace the body and rebuild it for much cheaper than a new one, so I'll go that route.
I didn't fancy rebuilding it myself..
Robbie
Robbie693
