wiring diagram 72+2S
PostPost by: jeff jackson » Sat May 24, 2008 7:37 am
Hi all,
Has anyone got a pdf wiring diagram of a UK 72 +2S that I could down load please?
After carefully labelling each wire, when I removed the dash, I now have partially working instrument lamps, and a clock that only works when the interior light is switched on. I am certain this is an earth problem. The only circuit diagram I have is for a 1970 model, and wire colours are not the same. And as most of the employees at Lotus at that time were colour blind, I don't think this makes much difference!
Any help greatfully received
Regards Jeff
jeff jackson
PostPost by: alaric » Sat May 24, 2008 7:22 pm
I've attached a .tif file of the wiring diagrams from the +2 manual. I've renamed it to a .doc so that the forum would allow me to upload it - rename to a .tif to open. Hope it helps.
Sean.
wiring.doc
Tif file of the wiring for the +2
(916.6 KiB) Downloaded 597 times
alaric
PostPost by: jeff jackson » Sat May 24, 2008 7:44 pm
Thanks Sean,
Unfortunately the encoding from tif to Doc has screwed it up and it's just ASCII.
Thanks for trying though.
Jeff
jeff jackson
PostPost by: jeff jackson » Sat May 24, 2008 7:53 pm
Hi Sean,
Sorry I am a muppet.
Even though I renamed the file, I forgot to tell windows to open with an image viewer. Works fine.
Thanks for that.
Jeff
jeff jackson
PostPost by: alaric » Sat May 24, 2008 9:47 pm
My pleasure. I notice that in the first two slides the model has been cut off. I've had a quick look in the original paper version and it just says Elan +2, which I presume means it's the non federal version.
The wiring is one of the next jobs that I have to get on with. It's a bit daunting as nothing at all is fitted at the moment. I guess I'll just start at one end of the car and work my way to the other, with the dash going in last...
All the best.
Sean.
alaric
