Headlamp vacuum units - one or two?
PostPost by: bruss » Fri May 09, 2008 4:00 pm
Hi I am restoring a Sprint (S4 bodyshell) that came without headlamps. Has the pods but nothing else. Early elans had two vacuum units (non fail safe) and later ones had a single unit with a cross bar. Anyone know the changeover dates from the twin (non fail safe) to the single (fail safe) units? Thanks.
68 plus 2 and 77? dhc - I'll take you out for a spin,- as soon as Ive got it working properly:-)
bruss
First Gear
First Gear
PostPost by: billwill » Fri May 09, 2008 7:47 pm
My second workshop manual dated March 1970 covers S1,2,3,4 and contains maintenance details for both non-fail-safe and fail-safe vacuum lifter/closer, so I imagine that all Sprints had the fail-safe single vacuum pod arrangement.
PostPost by: types26/36 » Fri May 09, 2008 8:07 pm
billwill wrote:I imagine that all Sprints had the fail-safe single vacuum pod arrangement.
I thought it was only the Fedral cars that had the fail safe headlights, my Sprint (domestic) does not have fail safe and that is a Oct 72 car.
Maybe the very last of the Sprints had them but like most things Lotus its difficult to pin down a specific change if it was a running change made during production.
types26/36
PostPost by: RichardS » Fri May 09, 2008 8:14 pm
My Sprint is a Feb 1973 car [UK] and, as with Brian's, does not have failsafe headlights.
Lotus Elan Sprint FHC 1973
RichardS
PostPost by: robcall » Fri May 09, 2008 11:23 pm
http://www.lotuselan.net/forums/viewtop ... ght=#62283
Now that your car is in bits-check for the serial number on the central transmission tunnel and inscribed inside the door moulding.This may give you an idea to the VIN.
Nigel Robertson
robcall
PostPost by: bruss » Sat May 10, 2008 6:59 am
Cheers all - checked the vin and manufacture date with Lotus but like all things Lotus They can only give me a year of manufacture nad don't have records of changes. I think that it is probably right that only the federal cars had the fail safe, so I'm going with the twin vacuum system. Thanks
bruss
First Gear
First Gear
PostPost by: Frank Howard » Sun May 11, 2008 12:26 am
My Federal S4 came from the factory with the single actuator fail safe system and although it works perfectly, I might be selling it soon. I want to install a radiator in the nose and if the vacuum actuator interfers, I'll go with electric actuators.
Frank Howard
'71 S4 SE
Minnesota
Frank Howard
PostPost by: 1964 S1 » Mon May 12, 2008 1:53 am
(Frank, if you remove it, IMHO don't sell it, keep it around so when the car eventually goes up for sale or to an heir, the original equipment is nearby.) Semi-original stickler, Eric
1964 S1
PostPost by: elansprint71 » Tue May 13, 2008 2:18 pm
May 72 Sprint......... 2 x vac units.
