clock
PostPost by: rocket » Thu Apr 24, 2008 9:28 am
Trying to work out if i need dash off to get to my time clocks wireing?..apparantly it was disconnected to save battery by a previous owner when car was little used...can i get to wireing under dash without removal?
rocket
PostPost by: rjaxe » Thu Apr 24, 2008 2:08 pm
I managed to dissconnect the wiring and remove the clock from my +2 S130 by first removing the trim panel under the glove compartment and loosening the clock clamps so it would rotate. Rotating gave just sufficient access the unhook the wiring and the clamps. Replacing and reconnecting was just as much a fiddle but again rotating the clock made it possible. (most of the scars on my fingers have now healed)
rjaxe
PostPost by: rocket » Thu Apr 24, 2008 2:30 pm
thanks richard,just got that far myself..iv attached wires as i think fit..but no ticking...have clock out now,its a kienzie,has just on tab to attach electrics to,and i imagine earth goes to clamping screw..so next ?. to test do i just connect to live feed from 12 volt battery?
rocket
PostPost by: rjaxe » Thu Apr 24, 2008 6:49 pm
That is all I did with mine, it is a Smiths but I doubt that there is much difference just make sure of the polarity is correct. I traced the problem with mine to a fault in the supply, I cannot explain it but even though I could measure full voltage the clock would not run for more than a few minutes, after cleaning all the connections from the fuse to the unit all has been OK for months.
rjaxe
PostPost by: john.p.clegg » Fri Apr 25, 2008 5:57 am
I can explain it....you can measure a good voltage reading at the component ,say 12v, but if there is a HR (high resistance connection) somewhere in line you will not be able to draw enough current for it to work correctly......
John :wink:
PostPost by: rocket » Fri Apr 25, 2008 9:41 am
or clock repairer to most..i wired to 12v no movement so have taken to a repairer...if it cant be repaired does anyone know where to source new clock? price?
rocket
PostPost by: rgh0 » Fri Apr 25, 2008 12:51 pm
clock not working is usually dirty electrical contacts in the electric drive mechanism. Clean the contacts and it normally works again
PostPost by: tcsoar » Fri Apr 25, 2008 1:08 pm
Pete Mallison who frequents this site, has one on flea-bay for sale, ?8 last time I looked, might be worth asking him the condition of it through here and if its worth it, but a bid in.
Chris.
tcsoar
PostPost by: elansprint » Fri Apr 25, 2008 2:16 pm
Kienzle clocks were used in triumph Stag & dolomites etc not sure if the are the same as lotus (2 different types in the stag) usually some pics.on flea bay under Stag
Ian
elansprint
PostPost by: rocket » Tue May 27, 2008 11:35 am
just a quick update,my clock has been repaired,a contact had burned out and a repairer replaced it,very delicate job,dont they tick loud...on another post of mine re honesty of p/o..i was told clock had been disconnected to save the battery.....
rocket
