how difficult is it to replace the reversing light switch..
PostPost by: tdafforn » Tue Dec 18, 2007 7:19 pm
like it says in title..
how difficult is it to replace the reversing light switch with the engine and gearbox in situ?
tim
tdafforn
PostPost by: carrierdave » Tue Dec 18, 2007 10:43 pm
Unless you have very small hands its almost impossible. Apart from the cylinder head the next main obstacle are the heater pipes.
Its not absolutely impossible its just like most of the things on a Lotus ? Difficult.
Getting it out was not too much of an issue ? getting it back in was far more difficult as you can not see if you have it upright in order to mesh with the screw thread.
A word of advise ? extend the cables on the switch so that you can then run a cable from inside the car to pull them back through ? if you leave them too short you will have a problem connecting them back up.
Good luck
Dave
carrierdave
PostPost by: ppnelan » Wed Dec 19, 2007 2:53 pm
If it's a Lotus 5-speed, the reversing light switch fits in the rear of the gearbox underneath, next & very close to the gearbox mounting.
:arrow: Matthew
ppnelan
PostPost by: tdafforn » Wed Dec 19, 2007 3:37 pm
looks like it isn't going to be a problem for now as the car failed the MOT on headlamps, wipers and a blowing manifold. No mention of reversing lights..
tim
tdafforn
PostPost by: mikealdren » Wed Dec 19, 2007 5:38 pm
Matthew,
I wouldn't expect reversing lights to be an MOT issue on a car of this age, most cars in the 1960s didn't have reversing lights fitted.
regards
mikealdren
PostPost by: john.p.clegg » Wed Dec 19, 2007 7:23 pm
Yes,but unfortunately if they are fitted they have to work.....
John :wink:
PostPost by: tdafforn » Wed Dec 19, 2007 7:27 pm
Hi John,
I am guessing they thought that they weren't fitted as no lights cam on when they selected reverse, whatever I am not complaining, and come to think of it, I am not sure I ever checked them before, so perhaps they have never worked!
tdafforn
PostPost by: lotusanglia1965 » Wed Dec 19, 2007 8:25 pm
Reversing lights aren't a testable item,fitted or not!
:wink:
good luck with the other jobs
"He's not the messiah, he's a very naughty boy"
Monty Python's The Life Of Brian,best film ever.
lotusanglia1965
PostPost by: memini55 » Thu Dec 20, 2007 2:11 am
Tim if your lights have never worked I would certainly bypass the switch from inside the car on the harness to make sure they work at all before attempting the switch change. Another thought could be it is not adjusted correctly and does not get engaged when set to reverse.
I have removed and adjusted will in the car and did this from below with the help of swivel mirror and light, not at all easy but can be done. I forgot to install with a rebuild this summer and had to install and fish the wires inside. I used a piece of tie wire and pushed it out from inside and taped the wires to it and pulled them thru.
Good Luck
memini55
PostPost by: carrierdave » Fri Dec 21, 2007 8:54 am
Hi Tim,
When I first got my car the PO had disconnected the rear heated screen and then used the heater switch as his manual reversing light switch. Since then I have adjusted the switch and reconnected every thing.
Dave
carrierdave
PostPost by: tdafforn » Fri Dec 21, 2007 9:08 am
my annoyance at the reversing lights failing is that I have become a DPO!
I have removed, rebuilt and replaced the engine this year, and I bet that I bashed the switch during the removal/replacement process, Doh!
tim
tdafforn
