Biscuit Shim Diameter.Question ..
Hi .I was pleased to get to the shim stage on my head .I got one size wrong but 7 out of 8.
Problem-- Burton Power shims = top quality.When I dropped them in the fit across the Diameter was very poor, rattling from side to side .When measured 60 thou difference to the old ones .I rang Burtons the chap was not too sure. So once again HELP PLEASE. Personaly I dont think they are correct.
Thanks Again
Thanks Again
- john.houston
From memory they are 5/8" diameter
Yes, just went and measured 5/8" (0.625") 15.9mm
John,
Sorry, can't find my spares today - the garage is too full of Zetec parts, I'll look again later.
However, I can tell you that from experience, shims are common across several makes and Hillman Imp and Jaguar shims are the same diameter and can be used. There are also later BL shims (Maxi??) that are the same.
I acquired a cache of Imp shims many years ago and they are totally interchangeable.
I suspect it's because they all have a common ancestry through the Jag and Coventry Climax engine, the engineers of the later engines having a background with these excellent engines.
- mikealdren
Thanks Brian . The Burton ones mic up at 0.562. A big difference .Am I being too cautious ?
John.
John.
- john.houston
john.houston wrote: The Burton ones mic up at 0.562. A big difference .Am I being too cautious ?
No, I wouldn't fit them, my opinion....too loose
0.562" equates to 9/16".....they are for some other type of engine
mikealdren wrote:However, I can tell you that from experience, shims are common across several makes and Hillman Imp and Jaguar shims are the same diameter and can be used. There are also later BL shims (Maxi??) that are the same.Mike
I'm not sure about the Jag ones Mike as I aquired a bag of shims that were suppose to be Jag and they are larger (0.687") 11/16"
.....and I've just found some in my collection that are 0.562" .....probally took them out of a T.C. at some time!
Pic shows left to right:
Kawasaki, Lotus, Jag(?)
