Radio question
Just removed the PO's aftermarket radio/cassette player, which never worked anyway.
Stunned to find that it seems to be a full-depth unit ! I thought only shallow units would fit, or is that only correct for +2's ?
Either that, or my PO's been more devious than I thought.
Stuart.
Stuart.
- stuartgb100
Thanks Rohan.
Thought that might be the case, since the recess where the radio was fitted did not look 'chopped' about, as it might do after someone's attempts to enlarge it.
Stuart.
Stuart.
- stuartgb100
Stuart,
The heater is mounted at an angle behind the dash. Thus there is more clearance at the top, but none (well, only enough for the switches) at the bottom.
If you wanted to modify the dash to fit a double din unit, for instance to install a navigation system or other such double high application, then you would have problems.
David
1968 36/7988
David
1968 36/7988
msd1107 - Fourth Gear
