2 Distributer questions.
Hi .I was checking my Distributer and the first thing I noticed was that the PO had used a fixed rotor arm (he used his right foot as a limiter).Could somone tell me the best type to fit and if possible where to get one- this would be the limiting type "Standard". For runnig in I want to keep the revs as low as possible. +2 1969.
Second I only have to turn and rock the distributer shaft to see that the bush needs changing.Where can I get one from please?
Thanks again
Thanks again
- john.houston
I dont know what costs are like in the UK but in Australia the rev limiting rotors cost over A$100 which is pretty expensive for an item with limited life. These days better to fit an electronic rev limiter at a cost of around A$200 in Australia and a standard rotor at a cost of around A$10 that you cant afford to replace. The electronic limiters also do a more accurate and reliable job.
New replacement bushes and shafts for the Lucas distributors were hard to get a few years ago, dont know if anybody remaking them now as I have not had to find any recently.
If you want the original type, there is a limiting rotor arm on eBay at the moment.
http://cgi.ebay.co.uk/LOTUS-CORTINA-MK1-MK2-ESCORT-ELAN-REV-LIMITER-NEW_W0QQitemZ250114590660QQihZ015QQcategoryZ31354QQrdZ1QQcmdZViewItem
dusty - Third Gear
Thanks very much Dusty. I will give it a bid .
- john.houston
