Headlight Problem
Hi all
Had a problem with the +2 other day. Popped up the headlights but they wouldn?t turn on.
After putting them up and down a few times they eventually worked. But after putting them down and up again I couldn?t get them back on.
They have been very Intermittent (more off then on) ever since.
The headlights go up and down with no problems and are on a non failsafe system. Side lights work OK
Anyone got any idea?s what the problem might be?
69 Elan +2
- Kets
Look at the wiring diagram in the workshop manual and you will find a contact switch, much like a courtesy light switch for the doors operated by the light pod when they go away from the down position. There are in fact two of these on the LH pod, one for the light circuit relay and the other for the flasher relay. any malfunction could be caused by any one of these components or the wiring and connectors. Have a first look at the earth connections. It sounds a bit laborious but it is the only way involving a process of elimination to solve a lack of illumination.
Gordon
(Rhubarb & Custard)
Gordon
(Rhubarb & Custard)
- gordonlund
I'd check the wires connected to the switches behind the dash too. Maybe remove wires one at a time, squirting electrical cleaner in the sockets one by one and sliding them back on. Or, it could be the switch itself, internally. Good Luck. Eric ps ; just re-read your description and I'll add, I'd do the same at the headlamps, remove and clean the wire connection sockets.
- 1964 S1
You should also check the contacts on the column stalk.
Berni
Berni
berni29 - Fourth Gear
Kets wrote:I did test the contact switch and it seems to be working OK.
I was going to replace it with a new one anyway but SJ 's says they are now obsolete.
anyone know where I can get one?
Hi Kets,
I am sure I got 2 for my S4 from Sue Miller, if you have not had anything from her before she is most helpful. May be not exactly original style but they do the job.
Doug
dougweall - Third Gear
Talked to Sue at Millers with no joy.
I have now taken the original switch apart and found it was full of old hard grease. I cleaned it up and put a smear of new grease on, cleaned the contacts and put it back together all seems ok now.
Thanks for the help.
69 Elan +2
- Kets
