signal-stat flasher unit
PostPost by: DaveyBoy » Sun Mar 25, 2007 2:33 pm
I see from browsing previous posts that i'm not alone with hazard flasher unit problems. My hazards lamps work fine, but the tell-tale tells no tale, as it were.
I have a 3 terminal "Signal-stat 180 12V Flasher". I've pulled the thing apart and with a bit of prodding have managed to get it to light the tell-tale on its first "click", but after that the little arm doesn't move. I guess it's simply not building up enough charge after that first pulse.
Does anyone know of a supplier of these units or whether the 3 terminal ones from Matty's are the same. The other question is whether there is something I can do to boost the current to the unit? If that sounds like a stupid question you will have to excuse my naivety as electrics are not my strong point.
DaveyBoy
First Gear
First Gear
PostPost by: berni29 » Mon Mar 26, 2007 1:08 am
Hi There
The one I used can be seen if you follow the link below, about half way down the page.
http://www.searchsmart.co.uk/lotus/2006_jan_feb.htm
If you are getting 12v to the unit it should be fine. These units can be picked up s/h for next to nothing.
Hope that helps.
Berni
berni29
PostPost by: denicholls2 » Mon Mar 26, 2007 4:01 pm
The symptoms you have are consistent with the use of LED bulbs. Are you doing this?
The "tell-tale" is oddly a leading indicator of insufficient current draw for the flasher unit, which is a bimetallic relay (like blinking Christmas tree bulbs).
In my case, I can run LED rear lights (Europa S2) and get exactly your symptoms (1 flash, with the actual indicators working fine). If I put in LED fronts, all blinking ceases.
If you're not using LED bulbs, you have some bad connections.
There are electronic replacements that don't use current load. Perhaps someone has a known easy replacement for reference.
denicholls2
