Electronic dizzy
As I am getting the +2 up to spec with a weber head I would also like to replace the dizzy with a electronic one mainly to save the hassle of fiddling with points. Has any one done this? and what type of unit is best?
Winter is here this week -32c time to stay indoors and plan for these modifications.
Geoff Minors
1969 Lotus Elan +2
1972 MGB (being restored)
1981 Fiat X19
1973 Norton 850 Commando
1969 Lotus Elan +2
1981 Fiat X19
gsminors - Second Gear
I installed the points replacement solid state ignition. I have used both "the igniter" and lumintion. Both of the hall effect type (i.e. not the light with a chopper blade). These units simply replace your points all contained within your existing distributor. There may be issues with you tachometer with them.
Mike Geiger
66 S3 Coupe', no more
type36lotus - Fourth Gear
If you can wait http://www.123ignition.nl/ are currently developing a solution for the twinc.
steveww - Coveted Fifth Gear
I replaced an old Lumenition set up (light beam and chopper type) with the Aldon Ignitor & coil (no balance resistor) and Magnecor ignition leads.
Dead easy to fit & set up and the ignitor stuff fits inside the dissy cap. The car starts easily and runs well. I'm also getting a little more MPG as well
Hamish.
Hamish.
Hamish Coutts - Fourth Gear
Oops,
Forgot to add that I don't have any trouble with a bouncing tach either. It wanders about a bit but I think that's just old age.
Hamish.
Hamish.
