Anti-Theft Switch
The anti-theft switch in the glove box has had the two white cables linked by a piece of wire soldered between the contacts - thus rendering it inoperative. Looking at the S4 wiring diagram it is clear what the switch did in make/break link between the ignition switch and coil, but what did the link do between the horn and earth/ground?
I have no real intention of using this switch as I normally use the battery master switch as security, therefore, I plan to make the whites a permanent connection, but am confused what to do with the purple/black and black cables.
All advice appreciated.
Brian Clarke
Brian Clarke
bcmc33 - Coveted Fifth Gear
In the anti-theft position, the horn circuit is grounded the same as if the horn button is pushed. So, when the ignition switch is turned the horn will be energized since the 12V supply to the horn circuit is thru the ignition switch (accessories position).
Dave, 72 Sprint DHC
Dave, 72 Sprint DHC
- dlbarnes1
Users browsing this forum: 1963 S1 and 14 guests
