Electric fan question?
I am mounting a full width radiator in my Elan and as such can't use the original electric fan bracket. I have therefore bought a nice new 10" Kenlowe blower fan.
The question is, should the fan be mounted in the middle of the radiator or at one side? My original electric fan was mounted to one side so I assume there must be a reason for this? Does one mount it closer to the top inlet side on the assumption that this is where the hotter water enters?
All suggestions welcome?
Carl
Carl
pereirac - Coveted Fifth Gear
I have just that configuration: Full radiator, electric fan on the exhaust side, no fan on the water pump pulley. If the fan is running the car stays cool even in stationary traffic on a hot day. (It would eventually flatten the battery though as i have a dynamo). If you are using an otterswitch, a relay will protect the contacts from too much current.
best regards, iain
best regards, iain
- iain.hamlton
OK----I handled the cooling with a different and very canny Scottish approach-----[too make my Granny proud ] the fan was a throw away from a friends Morgan ---so I bent some tube to make a stand and mounted it whole thing in the nose of the car -----I added an aluminum floor and sides to the cavity to control air flow and hooked the switch to the dash-----the fan also handles the oil cooler--and is far enough from the rad so that there is no blockage of the airrr flow ---the down side is in traffic one eye must be on the temp gage or just turn it on until things get rolling again -------total cost -----0 dollars ----hoot mun ----ed
Is that a fan Ed ?...........looks more like a propeller
twincamman wrote:OK----I handled the cooling with a different and very canny Scottish approach-----[too make my Granny proud ] the fan was a throw away from a friends Morgan ---so I bent some tube to make a stand and mounted the whole thing in the nose of the car -----I added an aluminum floor and sides to the cavity to control air flow and hooked the switch to the dash-----the fan also handles the oil cooler--and is far enough from the rad so that there is no blockage of the airrr flow ---the down side is in traffic one eye must be on the temp gage or just turn it on until things get rolling again -------total cost -----0 dollars ----hoot mun ----ed
well a propeller is just a BIG fan -- -may be something left over from the unpleasantness of the 40's that Morgan got a buy on ---and you get to say ---'CONTACT'--- when you turn it on -----helps with gas milage too --and on hot days stand close to the air intake and cool yur kilt -----its all good ------but keep the sheep away----ed--
